Ibis Fernandez
Ibis Fernandez
Posts: 1.2K,
Visits: 4.3K
Use code "no upgrade", you'll get it for about $40, but won't be eligible for upgrades.
Ibis Fernandez | (available for hire) ---------------------------------------------------------------------------------------- Professional Animator, Filmmaker | Creator of the highest quality (modular) G2 rigs for cartoon animator and developer of Toon Titan and Puppet Producer Author of Flash Animation and Cartooning: A Creative Guide >>> be sure to check out http://toontitan.com for professional grade assets, templates, and custom tools for Cartoon Animator and more.
Grace-E
Grace-E
Visits: 51
Thank you for your reply's. Is it possible to show us an example of how to create a simple character to export into CTA3? I saw a few of your wonderful videos, but I'm not quite sure how to use PP with CTA3. I would like to purchase Draw Plus X8 as my drawing tool (because it's inexpensive), and use it with CTA3 to create characters. But as you mentioned the rigging would be different. Can you do a short video example of how this would be working with PP & CTA3........ PRETTY PLEASE.... THANK YOU!!! : D
theschemer
theschemer
Posts: 1.4K,
Visits: 2.9K
You can get it for about $25 if you go here: http://www.serif.com/drawplus/TS
Ibis Fernandez
Ibis Fernandez
Posts: 1.2K,
Visits: 4.3K
Joylove (12/1/2016) Is it possible to show us an example of how to create a simple character to export into CTA3? There is really nothing to it. It works exactly the same way as it does for CTA2. The PP is only used with Flash. the resulting SWF fle is what you import into CT2 or CTA3 and its the same exact procedure.
myless76
myless76
Last Active: 6 Years Ago
Visits: 146
cool plugin!
Writer/Director of the feature film PLATO'S REALITY MACHINE Featuring IClone animation www.platosrealitymachine.com
GreedyPeopleSuck
GreedyPeopleSuck
Visits: 357
I bought the plugin, but can't get it to install following the instructions. Any ideas? Edit: I got it to work with 2014 Flash only. It seems that in Flash 2015 (Animate CC) versions and higher the extension manager is deprecated and they want everything through their annoying to use add-on store. Does this work with 64 bit Flash? Adobe are really bastards with all of these not really compatible versions. I previously have used Edge Animate, and I had to switch between three different versions depending on what I needed to do with the project. Nothing was backwards compatible there. Then they killed the project and everything DOM needs to be programmatically created with frameworks like greensock. There is nothing good HTML 5 to keyframe and develop playable games in. Steve Jobs and Google created a war on flash. However it's replacement, HTML 5, is more vulnerable, and less universal. Adobe should have opened up Flash source so we weren't sent 15 years back in time.
7 Years Ago by
nadiak
toonsunlimited
toonsunlimited
Visits: 4.3K
Nadiak, Use the ZXPInstaller. You should not have any problems. http://zxpinstaller.com/
GreedyPeopleSuck
GreedyPeopleSuck
Visits: 357
Works! This is the solution. Thank you very much. I had just updated that I got to work with Flash 2014 when I saw your reply. I was on stackoverflow and even github. I do not know how I did not find this answer, but this is the answer!
GreedyPeopleSuck
GreedyPeopleSuck
Visits: 357
Review for anyone thinking of purchasing:
I just took ten minutes what took over a day. It's probably good to learn the hard way and the hierarchy first, but this is well worth the money. Ibis is doing the lord's work making CrazyTalk great again. Praise Kek!
chckymickey
chckymickey
Last Active: 7 Years Ago
Visits: 18
not a word from " Ibis Fernandez" sad ...
