How do I create water flushing out of broken pipe
Posted By krystal studio 4 Years Ago
krystal studio
krystal studio
Junior Member (45 reputation)Junior Member (45 reputation)Junior Member (45 reputation)Junior Member (45 reputation)Junior Member (45 reputation)Junior Member (45 reputation)Junior Member (45 reputation)Junior Member (45 reputation)Junior Member (45 reputation)
Posts: 7, Visits: 162
How do I create this in iclone 5-
A Pipe burst and water flushes out of it gradually with full force..
This is for Doing Previz only.....
Any suggestions will be greatfull....
Tutor
Tutor (8.6K reputation)Tutor (8.6K reputation)Tutor (8.6K reputation)Tutor (8.6K reputation)Tutor (8.6K reputation)Tutor (8.6K reputation)Tutor (8.6K reputation)Tutor (8.6K reputation)Tutor (8.6K reputation)
Last Active: 6 hours ago
Posts: 5.0K, Visits: 14.9K
If your goal is "pre-vis" then the accuracy (visual quality) isn't as important as it would be if you were producing a final product in iClone.
Good.  That gives you more freedom.
I had moderate success using a cloth, and changing the material properties so it was reflective and nearly transparent.
Try searching the forum for "water".
Here's a link to a thread.  The last post on that thread includes a link to a little proof-of-concept video I made.
Someone else did a pretty cool fountain.
One last thing... You can apply a VIDEO as a texture.  So you actually us a solid pipe and then apply a "water" video to the pipe.  For pre-vis work it might be sufficient.
iClone6 Pro, and 3DXchange Pro
Homebuilt computer - Windows 7, i7-3770k CPU @ 3.50GHz, GTX 1080 GPU (8GB), 16GB 1600 MHz RAM, Asus P8Z77-V Pro motherboard, 500 GB SSD (Samsung 850 EVO) terabytes of disk space, and dual 28" monitors.
4 Years Ago by justaviking
Tutor
Tutor (4.7K reputation)Tutor (4.7K reputation)Tutor (4.7K reputation)Tutor (4.7K reputation)Tutor (4.7K reputation)Tutor (4.7K reputation)Tutor (4.7K reputation)Tutor (4.7K reputation)Tutor (4.7K reputation)
Last Active: 3 hours ago
Posts: 2.6K, Visits: 13.8K
There are several "waterfalls" available from the Marketplace - just type waterfall in the search field. You can adjust the size and rate of flow to get something like what you are looking for. Here's a quick example with no adjustments made:
System: Win 10 Pro, Asus X99-E WS, CPU i7-5930K -3,5 GHz, 32 GB DDR4 2666-16 RAM, Nvidia GTX 980 GPU(Driver 376.33), Samsung 850 Pro 512 GB SSD, 6 TB HD storage.
krystal studio
krystal studio
Thank you....
