Dreamcube017 (12/12/2012)
I hate to bring this back from the grave, but let me get this right.
So you're saying, I just rename a .lua to a .aml and I can use it in the AML editor? Then rename it back to a .lua and it'll work in iClone 5? I thought that AMLs saved with the editor had some other issue that made them not work in any newer version besides iClone 3.
So basically, I can still use the AML editor?
Thanks!The AML Editor is not fully compatible with iClone5 and you could run into problems using it. It will probably be easier to open the Persona as a text file if you wish to edit it.
